Using Cycling Dynamics
Before you can use cycling dynamics, you must pair the power meter with your device using ANT‍+® technology (Pairing Your Wireless Sensors).
NOTE: Recording cycling dynamics uses additional device memory.
  1. Go for a ride.
  2. Scroll to the cycling dynamics screen to view your power phase data 1, total power 2, and platform center offset 3.
    Cycling dynamics data with callouts
  3. If necessary, hold a data field 4 to change it (Adding a Data Screen).
    NOTE: The two data fields at the bottom of the screen can be customized.
You can send the ride to the Garmin Connect™ app to view additional cycling dynamics data (Sending Your Ride to Garmin Connect).
GUID-0083D0A0-EA6E-41F0-8207-3F1498875E61 v11
May 2026
