Sonar Settings
NOTE: Not all options and settings apply to all models, sounder modules, and transducers.
From a sonar view, select MENU > Sonar Setup.
Depth Line
Shows a quick-reference depth line.
Scroll Speed
Sets the rate at which the sonar scrolls from right to left.
In shallow water you might want to slow the scroll speed to extend the length of time the information is displayed on screen. In deeper water you can increase the scroll speed.
Range Lines
Shows the vertical lines indicating the distance to the right and left of the boat. This setting is available for SideVü sonar view.
Color Scheme
Sets the color scheme of the sonar view. This setting might be available in the Appearance menu.
The high contrast color schemes provide darker color assignments to the low intensity returns. The low contrast color schemes provide color assignments to the low intensity returns that are similar to the background color.
Appearance
See Sonar Appearance Settings.
Overlay Numbers
Sets the data shown on the sonar screen.
Advanced
See Advanced Sonar Settings.
Installation
Restores the default sonar settings.
Copyright © Garmin. All rights reserved.GUID-07BB0D0C-0781-43E3-BD62-8C02AFC68092 v5
