Sonar Appearance Settings
From a sonar view, select MENU > Sonar Setup > Appearance.
Color Scheme
Sets the color scheme.
Edge
Highlights the strongest signal from the bottom to help define the hardness or softness of the signal.
A-Scope
Displays a vertical flasher along the right side of the screen that shows instantaneously the range to targets along a scale.
Pic. Advance
Allows the sonar picture to advance faster by drawing more than one column of data on the screen for each column of sounder data received. This is especially helpful when you are using the sounder in deep water, because the sonar signal takes longer to travel to the water bottom and back to the transducer.
The 1/1 setting draws one column of information on the screen per sounder return. The 2/1 setting draws two columns of information on the screen per sounder return, and so on for the 4/1 and 8/1 settings.
Fish Symbols
Sets how the sonar interprets suspended targets.
Copyright © Garmin. All rights reserved.GUID-07BB0D0C-0781-43E3-BD62-8C02AFC68092 v5
