Adding or Removing a Favorite Activity
The list of your favorite activities appears when you press the key from the watch face, and it provides quick access to the activities you use most. The first time you press the key to start an activity, the device prompts you to select your favorite activities. You can add or remove favorite activities at any time.
  1. Hold the touchscreen.
  2. Select Settings > Activities & Apps.
    Your favorite activities appear at the top of the list with a white background. Other activities appear in the extended list with a black background.
  3. Select an option:
    • To add a favorite activity, select the activity, and select Add Favorite.
    • To remove a favorite activity, select the activity, and select Remove Favorite.
Copyright © Garmin. All rights reserved.GUID-2C040CDB-E8B7-4C5F-B988-C0D03356044D v4
