Setting Range Alerts
A range alert notifies you when the device is above or below a specified range of values. For example, if you have an optional heart rate monitor, you can set the device to alert you when your heart rate is below zone 2 and over zone 5 (Setting Your Heart Rate Zones).
Each time you exceed or drop below the specified range, a message appears. The device also vibrates if vibration is turned on (System Settings).
Parent Topic: Alerts
