Your
VIRB® camera can pair with a compatible
Bluetooth® ELM327 on-board diagnostics (ODB-II) device to record automotive data from your OBD-II compliant vehicle.
NOTE:
Different vehicles provide different data. Not all vehicles and OBD-II devices are compatible with the camera.
Install your ELM327 compatible OBD-II device in the OBD-II port of your vehicle.
TIP:
See the owner's manual for your vehicle and your OBD-II device for information about locating the OBD-II port and installing the OBD-II device.
If necessary, enable pairing mode on your OBD-II device.
TIP:
See the owner's manual for your OBD-II device to enable pairing mode.
From the
VIRB camera main menu, select
to turn on
Bluetooth wireless technology.
Select
Add New.
Select the OBD-II device to pair.
TIP:
If your OBD-II device does not appear in the list, confirm that it is still in pairing mode and search again.
After the OBD-II device is paired, the device status changes to
Connected.
