Heading Settings
You can customize the compass settings.
From the app drawer, select .
- Display
Sets the type of directional heading shown on the compass.
- North Reference
Sets the north reference used on the compass.
- Go To Line (Pointer)
Allows you to use the bearing pointer that points in the direction of your destination, or use the course pointer that shows your relationship to the course line leading to the destination.
- Compass
Automatically switches from an electronic compass to a GPS compass when you are traveling at a higher rate of speed for a period of time.
- Calibrate Compass
Allows you to calibrate the compass if you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes (Calibrating the Compass).
Parent Topic: Customizing the Device
