Training Intensities and Methods
You can use several methods to train your dog. The Pro 550 system provides 7 stimulation intensity levels, which increase sequentially from 1 to 7.
Momentary stimulation
Applies a brief stimulation when you press the training key, regardless of how long the key is depressed.
Continuous stimulation
Applies stimulation to the dog the entire time you press the training key, for a maximum of 8 seconds. Your stimulations should typically be much shorter than 8 seconds.
Tone
Activates an audible tone instead of stimulation. A tone can be used as either a positive or negative training cue, depending on your training program.
Vibration
Applies vibration instead of stimulation to the dog the entire time you press the training key, for a maximum of 8 seconds. The effectiveness of vibration may vary based on the dog's temperament and experience.
GUID-BAE7EA92-0BC4-4FBE-B7A0-20230308239D v5
July 2025
