Connecting a Spy Pole to a Garmin Chartplotter
A Spy™ pole can connect to one compatible Garmin® chartplotter at a time. After connecting a Spy™ pole to a chartplotter, you can control it using any other chartplotter connected to the same Garmin BlueNet™ or Garmin Marine Network.
Up to four Spy™ poles can connect to a Garmin BlueNet or Garmin Marine Network at the same time.
  1. Turn on the Spy™ pole.
  2. Press Power button on the Spy™ pole three times.
    The LED turns solid blue, indicating that the device is ready to connect.
  3. On the chartplotter, select Home > Settings > Communications > Wireless Devices > Spy™ Pole Mount > Start.
  4. Wait for the chartplotter to connect to the Spy™ pole.
    The LED on the Spy™ pole turns green again after the devices are connected successfully.
After you connect a Spy™ pole to a chartplotter successfully, you are prompted to complete the setup wizard on the chartplotter screen. It is highly recommended to complete the wizard at this time for the best results.
June 2026
