Selecting a Sonar Source
When you have more than one transducer providing data for a particular sonar view, you can select the source to use for that sonar view. For example, if you have two transducers providing Garmin ClearVü™ data, you can select the source to use for the Garmin ClearVü sonar view.
  1. Open the sonar view for which you will change the source.
    If the sonar view is in a combo screen, you must select the view you want to change.
  2. Select Options > Sonar Setup > Source.
  3. Select the source for this sonar view.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
