Weather Fronts and Pressure Centers
Weather fronts appear as lines that indicate the leading edge of an air mass.
Front Symbol
Description
Cold front
Cold front
Warm front
Warm front
Stationary front
Stationary front
Occluded front
Occluded front
Trough
Trough
Pressure-center symbols often appear near weather fronts.
Pressure-Center Symbol
Description
Low-pressure center symbol
Indicates a low-pressure center, which is a region of relatively lower pressure. Moving away from a low-pressure center results in increased pressure. Winds flow counterclockwise around low-pressure centers in the northern hemisphere.
High-pressure center symbol
Indicates a high-pressure center, which is a region of relatively higher pressure. Moving away from a high-pressure center results in decreased pressure. Winds flow clockwise around high-pressure centers in the northern hemisphere.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
