NMEA 0183 with Audio Cable Pinout
The NMEA® 0183 with audio cable (010-12852-00 or 010-12390-21) includes bare wires and an RCA connector for an audio out connection to a stereo, including Fusion® stereos. You can purchase this cable from garmin.com or your local Garmin® dealer.
After installing the cable, you can connect the RCA connectors to the AUX input of the stereo. The HDMI® input is then output to the stereo.
The cable also provides NMEA 0183 inputs and outputs.
Model
Accessory Part Number
NMEA 0183 Inputs and Outputs
10 inch
010-12852-00
One differential input and output port
12 inch
010-12852-00
16 inch
010-12852-00
17 inch
010-12390-21
Four input ports and two output ports
22 inch
010-12390-21
24 inch
010-12390-21
8700 black box
010-12390-21 (included)
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
