Configuring the Function Keys
The two keys labeled 1 and 2 on the keypad can be configured using a compatible chartplotter or a GHC™ 50 helm control connected to the autopilot system.
  1. From the autopilot screen, select Options > Autopilot Setup > Autopilot Keypad > Autopilot Keypad Configuration
  2. Select an option:
    • To configure the key labeled 1, select Key 1.
    • To configure the key labeled 2, select Key 2.
  3. Select the function you want to assign to the key.
  4. Repeat this procedure for the other key, if needed.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
