Customizing Engine Gauge and Fuel Gauge Limits
You can configure the upper and lower limits and the range of desired standard operation of a gauge.
NOTE: Not all options are available for all gauges.
  1. From an applicable gauges screen, select Options > Installation > Set Gauge Limits.
  2. Select a gauge to customize.
  3. Select an option:
    • To set the minimum value of the standard operating range, select Rated Min..
    • To set the maximum value of the standard operating range, select Rated Max..
    • To set the lower limit of the gauge lower than the rated minimum, select Scale Min..
    • To set the upper limit of the gauge higher than the rated maximum, select Scale Max..
  4. Select the limit value.
  5. Repeat steps 4 and 5 to set additional gauge limits.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
