Calibrating a Water-Speed Device
If you have a speed sensor or a speed-sensing transducer connected, you can calibrate that speed-sensing device to improve the accuracy of water-speed data displayed by the chartplotter.
  1. Complete an action:
    • If the sensor or transducer is connected to the chartplotter or a sonar module, select Settings menu > My Vessel > Calibrate Water Speed.
    • If the sensor or transducer is connected to the NMEA 2000® network, select Settings menu > Communications > NMEA 2000 Setup > Device List, select the transducer, and select Review > Calibrate Water Speed.
  2. Follow the on-screen instructions.
    If the boat is not moving fast enough or the speed sensor is not registering a speed, a message appears.
  3. Select OK, and safely increase the boat speed.
  4. If the message appears again, stop the boat, and ensure the speed-sensor wheel is not stuck.
  5. If the wheel turns freely, check the cable connections.
  6. If you continue to get the message, contact Garmin® product support.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
