GPSMAP 8x10 Specifications
Dimensions (W × H × D)
259.9 × 205.1 × 75.1.mm (101/4× 81/16 × 215/16 in.)
Dimensions on bail mount (W × H × D)
259.9 × 221.6 × 103.5.mm (111/16× 83/4 × 41/16 in.)
Display size (W × H)
218.4 × 136.9 mm (85/8  × 53/8  in.)
10 in. diagonal
Display resolution
WUXGA, 1920 × 1200 pixels
Weight
2.4 kg (5.2 lb.)
Compass-safe distance
45 cm (17.7 in.)
Clearance behind flush-mounted device
11.1 cm (43/8  in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX71
Fuse
10 A, 125 V fast-acting
Input voltage
From 10 to 32 Vdc
Max. power usage at 10 Vdc
40.1 W
Typical current draw at 12 Vdc
1.5 A
Max. current draw at 12 Vdc
6.0 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
Max. waypoints
5,000
Max. routes
100 (250 waypoints each)
Max. active track points
50,000 points, 50 saved tracks
Memory card
2 microSD® memory card slots, 32 GB max card size.
Wireless frequency and protocols
Wi‑Fi® and ANT® technologies
2.4 GHz @ 12.3 dBm nominal
HTML integration
Compatible with OneHelm™ integration
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
