Adjusting the Wind Sensor Orientation
You should adjust this setting if the sensor does not face the front of the boat, exactly parallel to the center line.
NOTE: The opening where the cable connects to the pole indicates the front of the sensor.
  1. Estimate the angle, in degrees clockwise around the mast, by which the sensor points away from the center of the front of the boat:
    • If the sensor is facing starboard, the angle should be between 1 and 180 degrees.
    • If the sensor is facing port, the angle should be between -1 and -180 degrees.
  2. Select Settings menu > Communications > Wireless Devices.
  3. Select the wind sensor.
  4. Select Wind Angle Offset.
  5. Enter the angle observed in step 1.
  6. Select Done.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
