Customizing the Startup Screen
You can personalize the image that is displayed when the chartplotter is turning on. For the best fit, the image should be 50 MB or less and conform to the recommended dimensions (Recommended Startup Image Dimensions).
  1. Insert a memory card that contains the image you want to use.
  2. Select Settings menu > System > Sounds and Display > Startup Image > Select Image.
  3. Select the memory card slot.
  4. Select the image.
  5. Select Set as Startup Image.
The new image is shown when turning on the chartplotter.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
