Engaging Wind Hold from Heading Hold
Before you can engage wind hold, you must connect a NMEA 2000® wind sensor to the autopilot.
Although a NMEA 2000 wind sensor is preferred, you can connect a NMEA® 0183 wind sensor to the autopilot to use wind hold.
  1. With heading hold engaged, select Options.
  2. Select an option:
    • To change from heading hold to apparent wind hold, select Engage App. Wind Hold.
    • To change from heading hold to true wind hold, select Engage True Wind Hold.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
