GPSMAP 8x22 Specifications
Specification
Measurement
Dimensions (W × H × D)
52.8 × 35.1 × 7.1 cm (20.8 × 13.8 × 2.8 in.)
Display size (W × H)
47.8 × 27.0 cm (18.8 × 10.6 in.)
Display resolution
FHD, 1920 × 1080 pixels
Weight
7.1 kg (15.63 lb.)
Compass-safe distance
Device: 68.58 cm (27 in.)
Device and sun cover: 111.76 cm (44 in.)
Sun cover: 43.18 cm (17 in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Fuse
15 A
Input voltage
From 10 to 35 Vdc
Max. power usage
59 W
Typical current draw at 12 Vdc
3.9 A
Typical current draw at 24 Vdc
1.8 A
Max. current draw
4.9 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
75 mA max.
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
Wireless frequency and protocols
Wi‑Fi®, ANT®, and Bluetooth® technologies
2.4 GHz @ 17.21 dBm max.
HTML integration
Compatible with OneHelm™ integration
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
