NMEA 0183 Settings
Select Settings menu > Communications > NMEA 0183 Setup.
Port Types
See Setting the Communication Format for Each NMEA 0183 Port.
Output Sentences
See Configuring NMEA 0183 Output Sentences.
Position Precision
Adjusts the number of digits to the right of the decimal point for transmission of NMEA® output.
XTE Precision
Adjusts the number of digits to the right of the decimal point for NMEA crosstalk error output.
Waypoint IDs
Sets the device to transmit waypoint names or numbers using NMEA 0183 while navigating. Using numbers may resolve compatibility issues with older NMEA 0183 autopilots.
Restore Defaults
Restores the NMEA 0183 settings to the original factory default values.
Diagnostics
Displays NMEA 0183 diagnostic information.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
