Adjusting the Distance from Shore
The Shoreline Distance setting indicates how close to the shore you want the Auto Guidance line to be placed. The Auto Guidance line may move if you change this setting while navigating. The available values for the Shoreline Distance setting are relative, not absolute. To ensure the Auto Guidance line is placed the appropriate distance from shore, you can assess the placement of the Auto Guidance line using one or more familiar destinations that require navigation through a narrow waterway.
  1. Dock your vessel or drop the anchor.
  2. Select Settings menu > Preferences > Navigation > Auto Guidance > Shoreline Distance > Normal.
  3. Select a destination that you have navigated to previously.
  4. Select Navigate To > Auto Guidance.
  5. Review the placement of the Auto Guidance line, and determine whether the line safely avoids known obstacles and the turns enable efficient travel.
  6. Select an option:
    • If the placement of the line is satisfactory, select Options > Navigation Options > Stop Navigation, and proceed to step 10.
    • If the line is too close to known obstacles, select Settings menu > Preferences > Navigation > Auto Guidance > Shoreline Distance > Far.
    • If the turns in the line are too wide, select Settings menu > Preferences > Navigation > Auto Guidance > Shoreline Distance > Near.
  7. If you selected Near or Far in step 6, review the placement of the Auto Guidance line, and determine whether the line safely avoids known obstacles and the turns enable efficient travel.
    Auto Guidance maintains a wide clearance from obstacles in open water, even if you set the Shoreline Distance setting to Near or Nearest. As a result, the chartplotter may not reposition the Auto Guidance line, unless the destination selected requires navigation through a narrow waterway.
  8. Select an option:
    • If the line is too close to known obstacles, select Settings menu > Preferences > Navigation > Auto Guidance > Shoreline Distance > Farthest.
    • If the turns in the line are too wide, select Settings menu > Preferences > Navigation > Auto Guidance > Shoreline Distance > Nearest.
  9. If you selected Nearest or Farthest in step 8, review the placement of the Auto Guidance line, and determine whether the line safely avoids known obstacles and the turns enable efficient travel.
    The Auto Guidance path maintains a wide clearance from obstacles in open water, even if you set the Shoreline Distance setting to Near or Nearest. As a result, the chartplotter may not reposition the Auto Guidance line, unless the destination selected requires navigation through a narrow waterway.
  10. Repeat steps 3 through 9 at least once more, using a different destination each time, until you are familiar with the functionality of the Shoreline Distance setting.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
