Selecting the Transducer Type
This chartplotter is compatible with a range of accessory transducers, including the Garmin ClearVü™ transducers, which are available at garmin.com/transducers.
If you are connecting a transducer that was not included with the chartplotter, you may need to set the transducer type to make the sonar function properly.
NOTE: Not all chartplotters and sonar modules support this feature.
  1. Complete an action:
    • From a sonar view, select Options > Sonar Setup > Installation > Transducers.
    • Select Settings menu > My Vessel > Transducers.
  2. Select the transducer that you want to change, and select Change Model.
  3. Select an option:
    • To enable the chartplotter to detect the transducer automatically, select Auto Detect.
    • To select the transducer manually, select the option that matches the installed transducer, such as Dual Beam (200/77 kHz) or Dual Freq (200/50 kHz).
      NOTICE
      Manually selecting a transducer could result in damage to the transducer or reduced transducer performance.
      NOTE: If you select the transducer manually, disconnect that transducer, and then connect a different transducer, you should reset this option to Auto Detect.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
