Mercury Troll Control Features
WARNING
You are responsible for the safe and prudent operation of your vessel. The Mercury® troll control features do not steer the boat for you and do not avoid navigational hazards. Failure to safely operate your boat could result in an accident causing property damage, serious personal injury, or death.
When connected to a compatible Mercury engine, you can use the Mercury Troll overlay to set and adjust the trolling speed from the chartplotter.
Adding the Mercury Troll Control Overlay
When connected to a compatible Mercury engine, you can set and adjust the target speed using the Mercury Troll overlay on the chartplotter.
  1. From the page where you want to add the overlay, select Options > Edit Overlays.
    TIP: You can also select Toolbars from the menu bar to quickly change the overlays.
  2. Select Top Bar, Bottom Bar, Left Bar, or Right Bar.
  3. Select Mercury Troll.
  4. Select Back.
Mercury Troll Overlay
When connected to a compatible Mercury engine, you can use the Mercury Troll overlay on the chartplotter to set a target speed.
Mercury troll control bar with callouts
Minus symbol
Select to decrease the target speed
1
Target speed
Plus symbol
Select to increase the target speed
2
Actual speed
Enable
Select to engage the Mercury Troll feature
Disable
Select to disengage the Mercury Troll feature
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
