Sharing Your Garmin Quickdraw Contours Maps with the Garmin Quickdraw Community Using ActiveCaptain
You can share Garmin Quickdraw™ Contours maps that you have created with others in the Garmin Quickdraw Community.
When you share a contour map, only the contour map is shared. Your waypoints are not shared.
When you set up your ActiveCaptain® app, you may have selected to share your contours with the community automatically. If not, follow these steps to enable sharing.
From the ActiveCaptain app on your mobile device, select Sync with Plotter > Contribute to Community.
The next time you connect the ActiveCaptain app to the GPSMAP® device, your contour maps are transferred to the community automatically.
GUID-25CCEC48-337E-47C0-8B89-5C35CCDB65AC v34
January 2026
