Going for a Run
The first fitness activity you record on your device can be a run, ride, or any outdoor activity. You may need to charge the device before starting the activity (Charging the Device).
  1. Select START, and select an activity.
  2. Go outside, and wait while the device locates satellites.
  3. Select START to start the timer.
  4. Go for a run.
    Activity timer with run data
  5. After you complete your run, select STOP to stop the timer.
  6. Select an option:
    • Select Resume to restart the timer.
    • Select Save to save the run and reset the timer. You can select the run to view a summary.
      Run summary data
    • Select Resume Later to suspend the run and continue recording later.
    • Select Lap to mark a lap.
    • Select Discard > Yes to delete the run.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
