Broadcasting Heart Rate Data to Garmin Devices
You can broadcast your heart rate data from your Forerunner® device and view it on paired Garmin® devices.
NOTE: Broadcasting heart rate data decreases battery life.
  1. From the heart rate widget, hold Menu symbol.
  2. Select Options > Broadcast Heart Rate.
    The Forerunner device starts broadcasting your heart rate data, and Heart rate broadcast symbol appears.
    NOTE: You can view only the heart rate widget while broadcasting heart rate data from the heart rate widget.
  3. Pair your Forerunner device with your Garmin ANT‍+® compatible device.
    NOTE: The pairing instructions differ for each Garmin compatible device. See your owner's manual.
    TIP: To stop broadcasting your heart rate data, select any key, and select Yes.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
