Training with Running Dynamics
Before you can view running dynamics, you must put on the HRM‍-‍Run™ accessory, HRM‍-‍Tri™ accessory, or Running Dynamics Pod, and pair it with your device (Pairing ANT‍+ Sensors).
If your Forerunner® was packaged with the heart rate monitor, the devices are already paired, and the Forerunner is set to display running dynamics.
  1. Select START, and select a running activity.
  2. Select START.
  3. Go for a run.
  4. Scroll to the running dynamics screens to view your metrics.
    Running dynamics data
  5. If necessary, hold UP to edit how the running dynamics data appears.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
