Going for a Run Using a Foot Pod
Before you go for a run, you must pair the foot pod with your Forerunner® device (Pairing ANT‍+ Sensors).
You can run indoors using a foot pod to record pace, distance, and cadence. You can also run outdoors using a foot pod to record cadence data with your GPS pace and distance.
  1. Install your foot pod according to the accessory instructions.
  2. Select a running activity.
  3. Go for a run.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
