Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. From the watch face, hold Menu symbol.
  2. Select Settings > Widgets.
  3. Select a widget.
  4. Select an option:
    • Select Reorder to change the location of the widget in the widget loop.
    • Select Remove to remove the widget from the widget loop.
  5. Select Add Widgets.
  6. Select a widget.
    The widget is added to the widget loop.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
