Customizing the Controls Menu
You can add, remove, and change the order of the shortcut menu options in the controls menu (Viewing the Controls Menu).
From the watch face, hold
- Select .
- Select a shortcut to customize.
Select an option:
Select Reorder to change the location of the shortcut in the controls menu.
Select Remove to remove the shortcut from the controls menu.
- If necessary, select Add New to add an additional shortcut to the controls menu.
Parent Topic: Widgets
