Setting an Alarm
You can set up to ten separate alarms. You can set each alarm to sound once or to repeat regularly.
From the watch face, hold
- Select .
- Select Time, and enter the alarm time.
- Select Repeat, and select when the alarm should repeat (optional).
- Select Sounds, and select a type of notification (optional).
- Select to turn on the backlight with the alarm.
- Select Label, and select a description for the alarm (optional).
Parent Topic: Clock
