Using Electronic Shifters
Before you can use compatible electronic shifters, such as Shimano® Di2™ shifters, you must pair them with your device (Pairing ANT‍+ Sensors). You can customize the optional data fields (Customizing the Data Screens). The Forerunner® device displays current adjustment values when the sensor is in adjustment mode.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
