Starting an Activity When you start an activity, GPS turns on automatically (if required). Select START. Select an activity. NOTE: Activities set as favorites appear first in the list (Customizing Your Activity List). If the activity requires GPS signals, go outside to an area with a clear view of the sky. TIP: If GPS appears in gray text or on a gray background, the activity does not require GPS signals. Wait until Ready appears on the screen. The device is ready after it establishes your heart rate, acquires GPS signals (if required), and connects to your wireless sensors (if required). Select START to start the timer. The device records activity data only while the activity timer is running. Child Topics:Tips for Recording ActivitiesParent Topic: Activities and Apps
Starting an Activity When you start an activity, GPS turns on automatically (if required). Select START. Select an activity. NOTE: Activities set as favorites appear first in the list (Customizing Your Activity List). If the activity requires GPS signals, go outside to an area with a clear view of the sky. TIP: If GPS appears in gray text or on a gray background, the activity does not require GPS signals. Wait until Ready appears on the screen. The device is ready after it establishes your heart rate, acquires GPS signals (if required), and connects to your wireless sensors (if required). Select START to start the timer. The device records activity data only while the activity timer is running. Child Topics:Tips for Recording ActivitiesParent Topic: Activities and AppsHomeActivities and AppsStarting an Activity
