Before you can start a
GroupTrack session, you must have a
Garmin Connect™ account, a compatible smartphone, and the
Garmin Connect Mobile app.
These instructions are for starting a
GroupTrack session with
Forerunner® devices. If your connections have other compatible devices, you can see them on the map. The other devices may not be able to display
GroupTrack riders on the map.
Go outside, and turn on the
Forerunner device.
Pair your smartphone with the
Forerunner device (Pairing Your Smartphone with Your Device).
On the
Forerunner device, hold
, and select
to enable viewing connections on the map screen.
In the
Garmin Connect Mobile app, from the settings menu, select
If you have more than one compatible device, select a device for the
GroupTrack session.
Select
Select
Start LiveTrack.
On the
Forerunner device, start an activity.
Scroll to the map to view your connections.
TIP:
From the map, you can hold
and select
Nearby Connections to view distance, direction, and pace or speed information for other connections in the
GroupTrack session.
