Changing the GPS Setting
By default, the device uses GPS to locate satellites. For more information about GPS, go to www.garmin.com/aboutGPS.
  1. Hold Menu symbol.
  2. Select Settings > Activities & Apps.
  3. Select the activity to customize.
  4. Select the activity settings.
  5. Select GPS.
  6. Select an option:
    • Select Normal (GPS Only) to enable the default GPS satellite system.
    • Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility.
    • Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility.
    • Select UltraTrac to record track points and sensor data less frequently (UltraTrac)
    NOTE: Using GPS and another satellite together can reduce battery life more quickly than using GPS only (GPS and Other Satellite Systems).
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
