Data Fields
%FTP
The current power output as a percentage of functional threshold power.
%HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
10s Avg. Power
The 10-second moving average of power output.
10s Avg Balance
The 10-second moving average of the left/right power balance.
24-Hour Max.
The maximum temperature recorded in the last 24 hours from a compatible temperature sensor.
24-Hour Min.
The minimum temperature recorded in the last 24 hours from a compatible temperature sensor.
30s Avg. Power
The 30-second moving average of power output.
30s Avg Balance
The 30-second moving average of the left/right power balance.
3s Avg. Balance
The three-second moving average of the left/right power balance.
3s Avg. Power
The 3-second moving average of power output.
500m Pace
The current rowing pace per 500 meters.
Aerobic TE
The impact of the current activity on your aerobic fitness level.
Ambient Press.
The uncalibrated ambient pressure.
Anaerobic TE
The impact of the current activity on your anaerobic fitness level.
Average HR
The average heart rate for the current activity.
Average Pace
The average pace for the current activity.
Average Power
The average power output for the current activity.
Average Swolf
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Avg. 500m Pace
The average rowing pace per 500 meters for the current activity.
Avg. Ascent
The average vertical distance of ascent since the last reset.
Avg. Balance
The average left/right power balance for the current activity.
Avg. Cadence
Cycling. The average cadence for the current activity.
Avg. Cadence
Running. The average cadence for the current activity.
Avg. Descent
The average vertical distance of descent since the last reset.
Avg. GCT Bal.
The average ground contact time balance for the current session.
Avg. L. PP
The average power phase angle for the left leg for the current activity.
Avg. L. PPP
The average power phase peak angle for the left leg for the current activity.
Avg. Lap Time
The average lap time for the current activity.
Avg. Moving Speed
The average speed when moving for the current activity.
Avg. Overall Speed
The average speed for the current activity, including both moving and stopped speeds.
Avg. PCO
The average platform center offset for the current activity.
Avg. R. PP
The average power phase angle for the right leg for the current activity.
Avg. R. PPP
The average power phase peak angle for the right leg for the current activity.
Avg. Speed
The average speed for the current activity.
Avg. Stride Len.
The average stride length for the current session.
Avg. Strk/Len
The average number of strokes per pool length during the current activity.
Avg. Strk Rate
Swimming. The average number of strokes per minute (spm) during the current activity.
Avg. Strk Rate
Paddle sports. The average number of strokes per minute (spm) during the current activity.
Avg. Vert. Osc.
The average amount of vertical oscillation for the current activity.
Avg. Vert. Ratio
The average ratio of vertical oscillation to stride length for the current session.
Avg Dist Per Stk
Swimming. The average distance traveled per stroke during the current activity.
Avg Dist Per Stk
Paddle sports. The average distance traveled per stroke during the current activity.
Avg GCT
The average amount of ground contact time for the current activity.
Avg HR %Max.
The average percentage of maximum heart rate for the current activity.
Balance
The current left/right power balance.
Baro. Pressure
The calibrated current pressure.
Battery Level
The remaining battery power.
Bearing
The direction from your current location to a destination. You must be navigating for this data to appear.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence
Running. The steps per minute (right and left).
Calories
The amount of total calories burned.
Compass Hdg.
The direction you are moving based on the compass.
Course
The direction from your starting location to a destination. Course can be viewed as a planned or set route. You must be navigating for this data to appear.
Dest. Location
The position of your final destination.
Dest. Wpt
The last point on the route to the destination. You must be navigating for this data to appear.
Di2 Battery
The remaining battery power of a Di2 sensor.
Dist. Per Stroke
Swimming. The distance traveled per stroke.
Dist. Per Stroke
Paddle sports. The distance traveled per stroke.
Dist. Remaining
The remaining distance to the final destination. You must be navigating for this data to appear.
Distance
The distance traveled for the current track or activity.
Distance To Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
ETA
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
ETE
The estimated time remaining until you reach the final destination. You must be navigating for this data to appear.
Front
The front bike gear from a gear position sensor.
GCT
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
GCT Balance
The left/right balance of ground contact time while running.
Gear Combo
The current gear combination from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
Gears
The front and rear bike gears from a gear position sensor.
Glide Ratio
The ratio of horizontal distance traveled to the change in vertical distance.
Glide Ratio Dest.
The glide ratio required to descend from your current position to the destination elevation. You must be navigating for this data to appear.
GPS
The strength of the GPS satellite signal.
GPS Elevation
The altitude of your current location using GPS.
GPS Heading
The direction you are moving based on GPS.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Int. Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Avg. %Max.
The average percentage of maximum heart rate for the current swim interval.
Int. Avg. HR
The average heart rate for the current swim interval.
Int. Distance
The distance traveled for the current interval.
Int. Max. %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Max. %Max.
The maximum percentage of maximum heart rate for the current swim interval.
Int. Max. HR
The maximum heart rate for the current swim interval.
Int. Pace
The average pace for the current interval.
Int. Swolf
The average swolf score for the current interval.
Intensity Factor
The Intensity Factor™ for the current activity.
Interval Lengths
The number of pool lengths completed during the current interval.
Interval Time
The stopwatch time for the current interval.
Int Strk/Len
The average number of strokes per pool length during the current interval.
Int Strk Rate
The average number of strokes per minute (spm) during the current interval.
Int Strk Type
The current stroke type for the interval.
L. Lap Stk. Rate
Swimming. The average number of strokes per minute (spm) during the last completed lap.
L. Lap Stk. Rate
Paddle sports. The average number of strokes per minute (spm) during the last completed lap.
L. Lap Strokes
Swimming. The total number of strokes for the last completed lap.
L. Lap Strokes
Paddle sports. The total number of strokes for the last completed lap.
L. Lap Swolf
The swolf score for the last completed lap.
L. Len. Stk. Rate
The average number strokes per minute (spm) during the last completed pool length.
L. Len. Stk. Type
The stroke type used during the last completed pool length.
L. Len. Strokes
The total number of strokes for the last completed pool length.
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap 500m Pace
The average rowing pace per 500 meters for the current lap.
Lap Ascent
The vertical distance of ascent for the current lap.
Lap Balance
The average left/right power balance for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Descent
The vertical distance of descent for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap Dist Per Stk
Swimming. The average distance traveled per stroke during the current lap.
Lap Dist Per Stk
Paddle sports. The average distance traveled per stroke during the current lap.
Lap GCT
The average amount of ground contact time for the current lap.
Lap GCT Bal.
The average ground contact time balance for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Lap L. PP
The average power phase angle for the left leg for the current lap.
Lap L. PPP
The average power phase peak angle for the left leg for the current lap.
Lap NP
The average Normalized Power for the current lap.
Lap Pace
The average pace for the current lap.
Lap PCO
The average platform center offset for the current lap.
Lap Power
The average power output for the current lap.
Lap R. PP
The average power phase angle for the right leg for the current lap.
Lap R. PPP
The average power phase peak angle for the right leg for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Stride Len.
The average stride length for the current lap.
Lap Strk Rate
Swimming. The average number of strokes per minute (spm) during the current lap.
Lap Strk Rate
Paddle sports. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Swimming. The total number of strokes for the current lap.
Lap Strokes
Paddle sports. The total number of strokes for the current lap.
Lap Swolf
The swolf score for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vert. Osc.
The average amount of vertical oscillation for the current lap.
Lap Vert. Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Last Lap Ascent
The vertical distance of ascent for the last completed lap.
Last Lap Cad.
Cycling. The average cadence for the last completed lap.
Last Lap Cad.
Running. The average cadence for the last completed lap.
Last Lap Descent
The vertical distance of descent for the last completed lap.
Last Lap Dist.
The distance traveled for the last completed lap.
Last Lap NP
The average Normalized Power for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Len. Pace
The average pace for your last completed pool length.
Last Len. Swolf
The swolf score for the last completed pool length.
Lat/Lon
The current position in latitude and longitude regardless of the selected position format setting.
Left PP
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Left PPP
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Lengths
The number of pool lengths completed during the current activity.
LL 500m Pace
The average rowing pace per 500 meters for the last lap.
L Lap Dist P Stk
Swimming. The average distance traveled per stroke during the last completed lap.
L Lap Dist P Stk
Paddle sports. The average distance traveled per stroke during the last completed lap.
Location
The current position using the selected position format setting.
Max. Ascent
The maximum rate of ascent in feet per minute or meters per minute since the last reset.
Max. Descent
The maximum rate of descent in meters per minute or feet per minute since the last reset.
Max. Elevation
The highest elevation reached since the last reset.
Max. Lap Power
The top power output for the current lap.
Maximum Speed
The top speed for the current activity.
Max Power
The top power output for the current activity.
Min. Elevation
The lowest elevation reached since the last reset.
Moving Time
The total time moving for the current activity.
Multisport Time
The total time for all sports in a multisport activity, including transitions.
Muscle O2 Sat. %
The estimated muscle oxygen saturation percentage for the current activity.
Nautical Dist
The distance traveled in nautical meters or nautical feet.
Nautical Speed
The current speed in knots.
Next Waypoint
The next point on the route. You must be navigating for this data to appear.
NP
The Normalized Power™ for the current activity.
Off Course
The distance to the left or right by which you have strayed from the original path of travel. You must be navigating for this data to appear.
Pace
The current pace.
PCO
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
Pedal Smooth.
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Perform. Cond.
The performance condition score is a real-time assessment of your ability to perform.
Power
The current power output in watts.
Power to Weight
The current power measured in watts per kilogram.
Power Zone
The current range of power output (1 to 7) based on your FTP or custom settings.
Rear
The rear bike gear from a gear position sensor.
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Rest Timer
The timer for the current rest (pool swimming).
Right PP
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Right PPP
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Speed
The current rate of travel.
Stopped Time
The total time stopped for the current activity.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Stroke Rate
Swimming. The number of strokes per minute (spm).
Stroke Rate
Paddle sports. The number of strokes per minute (spm).
Strokes
Swimming. The total number of strokes for the current activity.
Strokes
Paddle sports. The total number of strokes for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor. You can pair a tempe™ sensor with your device to provide a consistent source of accurate temperature data.
Time in Zone
The time elapsed in each heart rate or power zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The current time of the countdown timer.
Time Seat.
The time spent seated while pedaling for the current activity.
Time Seat. Lap
The time spent seated while pedaling for the current lap.
Time Stand.
The time spent standing while pedaling for the current activity.
Time Stand. Lap
The time spent standing while pedaling for the current lap.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Torque Eff.
The measurement of how efficiently a rider is pedaling.
Total Ascent
The total elevation distance ascended since the last reset.
Total Descent
The total elevation distance descended since the last reset.
Total Hemoglobin
The estimated muscle oxygen total for the current activity.
TSS
The Training Stress Score™ for the current activity.
V Dist to Dest
The elevation distance between your current position and the final destination. You must be navigating for this data to appear.
Vert. Spd.
The rate of ascent or descent over time.
Vertical Osc.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Vert Spd to Tgt
The rate of ascent or descent to a predetermined altitude. You must be navigating for this data to appear.
VMG
The speed at which you are closing on a destination along a route. You must be navigating for this data to appear.
Work
The accumulated work performed (power output) in kilojoules.
Copyright © Garmin. All rights reserved.GUID-0E0F9623-9BBE-4495-B00F-7BCAADFD4B48 v4
