Navigating to a Saved Location Before you can navigate to a saved location, your device must locate satellites. Select Menu > Navigation > Saved Locations. Select a location. Select Go To. The compass appears. The arrow points toward the saved location. Select to view the map (optional). A line appears on the map from your current location to the saved location. Select to start the timer and record the activity. Parent Topic: NavigationHomeNavigationNavigating to a Saved Location
