Pairing ANT‍+® Sensors
Pairing is the connecting of ANT‍+ wireless sensors, for example, connecting a heart rate monitor with your Garmin® device. The first time you connect an ANT‍+ sensor to your device, you must pair the device and sensor. After the initial pairing, the device automatically connects to the sensor when you start your activity and the sensor is active and within range.
NOTE: If your device was packaged with an ANT‍+ sensor, they are already paired.
  1. Install the sensor or put on the heart rate monitor.
  2. Bring the device within 1 cm of the sensor, and wait while the device connects to the sensor.
    When the device detects the sensor, a message appears. You can customize a data field to display sensor data.
  3. If necessary, select Menu > Settings > Sensors and Accessories to manage ANT‍+ sensors.
