Color Gauges and Running Dynamics Data
The running dynamics screens display a color gauge for the primary metric. You can display cadence, vertical oscillation, ground contact time, ground contact time balance, or vertical ratio as the primary metric. The color gauge shows you how your running dynamics data compare to those of other runners. The color zones are based on percentiles.
Garmin® has researched many runners of all different levels. The data values in the red or orange zones are typical for less experienced or slower runners. The data values in the green, blue, or purple zones are typical for more experienced or faster runners. More experienced runners tend to exhibit shorter ground contact times, lower vertical oscillation, lower vertical ratio, and higher cadence than less experienced runners. However, taller runners typically have slightly slower cadences, longer strides, and slightly higher vertical oscillation. Vertical ratio is your vertical oscillation divided by stride length. It is not correlated with height.
NOTE: The color gauge for ground contact time balance is different (Ground Contact Time Balance Data).
Go to www.garmin.com/runningdynamics for more information on running dynamics. For additional theories and interpretations of running dynamics data, you can search reputable running publications and websites.
Color Zone
Percentile in Zone
Cadence Range
Vertical Oscillation Range
Vertical Ratio
Ground Contact Time Range
Purple Purple
>95
>183 spm
<6.4 cm
<6.1%
<218 ms
Blue Blue
70–95
174–183 spm
6.4–8.1 cm
6.1–7.4%
218–248 ms
Green Green
30–69
164–173 spm
8.2–9.7 cm
7.5–8.6%
249–277 ms
Orange Orange
5–29
153–163 spm
9.8–11.5 cm
8.7–10.1%
278–308 ms
Red Red
<5
<153 spm
>11.5 cm
>10.1%
>308 ms
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
