Data Fields
Some data fields require ANT‍+® accessories to display data.
%FTP
The current power output as a percentage of functional threshold power.
%HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
10s Avg. Balance
The 10-second moving average of the left/right power balance.
10s Avg. Power
The 10-second moving average of power output.
24-Hour Max.
The maximum temperature recorded in the last 24 hours.
24-Hour Min.
The minimum temperature recorded in the last 24 hours.
30s Avg. Balance
The 30-second moving average of the left/right power balance.
30s Avg. Power
The 30-second moving average of power output.
3s Avg. Balance
The three-second moving average of the left/right power balance.
3s Avg. Power
The three-second moving average of power output.
Average %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average Balance
The average left/right power balance for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Average Cadence
Cycling. The average cadence for the current activity.
Average Heart Rate
The average heart rate for the current activity.
Average HR %Max.
The average percentage of maximum heart rate for the current activity.
Average Lap Time
The average lap time for the current activity.
Average Pace
The average pace for the current activity.
Average Power
The average power output for the current activity.
Average Speed
The average speed for the current activity.
Average Stroke Distance
The average distance traveled per stroke during the current activity.
Average Stroke Rate
Swimming. The average number of strokes per minute (spm) during the current activity.
Average Strokes/Length
The average number of strokes per pool length during the current activity.
Average SWOLF
The average swolf score for the current activity. Your swolf score is the sum of the time for one length plus the number of strokes for that length (Swim Terminology). In open water swimming, 25 meters is used to calculate your swolf score.
Avg. GCT Bal.
The average ground contact time balance for the current session.
Avg. Ground Contact Time
The average amount of ground contact time for the current activity.
Avg. L. Pwr. Phase
The average power phase angle for the left leg for the current activity.
Avg. Left PPP
The average power phase peak angle for the left leg for the current activity.
Avg. PCO
The average platform center offset for the current activity.
Avg. R. Pwr. Phase
The average power phase angle for the right leg for the current activity.
Avg. Right PPP
The average power phase peak angle for the right leg for the current activity.
Avg. Stride Len.
The average stride length for the current session.
Avg. Vert. Ratio
The average ratio of vertical oscillation to stride length for the current session.
Avg. Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Balance
The current left/right power balance.
Cadence
Running. The steps per minute (right and left).
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Calories
The amount of total calories burned.
Di2 Battery
The remaining battery power of a Di2 sensor.
Distance
The distance traveled for the current track or activity.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
Front
The front bike gear from a Di2 sensor.
GCT Balance
The left/right balance of ground contact time while running.
Gear Combo
The current gear combination from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears.
Gears
The front and rear bike gears from a Di2™ sensor.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Int. Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Avg. %Max.
The average percentage of maximum heart rate for the current swim interval.
Int. Avg. HR
The average heart rate for the current swim interval.
Int. Max. %HRR
The maximum percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current swim interval.
Int. Max. %Max
The maximum percentage of maximum heart rate for the current swim interval.
Int. Max. HR
The maximum heart rate for the current swim interval.
Intensity Factor
The Intensity Factor™ for the current activity.
Interval Distance
The distance traveled for the current interval.
Interval Lengths
The number of pool lengths completed during the current interval.
Interval Pace
The average pace for the current interval.
Interval Stroke Rate
The average number of strokes per minute (spm) during the current interval.
Interval Strokes/Length
The average number of strokes per pool length during the current interval.
Interval Stroke Type
The current stroke type for the interval.
Interval SWOLF
The average swolf score for the current interval.
Interval Time
The stopwatch time for the current interval.
L. Pwr. Phase
The current power phase angle for the left leg. Power phase is the pedal stroke region where you produce positive power.
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Balance
The average left/right power balance for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap GCT Bal.
The average ground contact time balance for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Lap L. Pwr. Phase
The average power phase angle for the left leg for the current lap.
Lap Left PPP
The average power phase peak angle for the left leg for the current lap.
Lap Normalized Power
The average Normalized Power for the current lap.
Lap Pace
The average pace for the current lap.
Lap PCO
The average platform center offset for the current lap.
Lap Power
The average power output for the current lap.
Lap R. Pwr. Phase
The average power phase angle for the right leg for the current lap.
Lap Right PPP
The average power phase peak angle for the right leg for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Stride Len.
The average stride length for the current lap.
Lap Stroke Distance
Swimming. The average distance traveled per stroke during the current lap.
Lap Stroke Rate
Swimming. The average number of strokes per minute (spm) during the current lap.
Lap Strokes
Swimming. The total number of strokes for the current lap.
Lap SWOLF
The swolf score for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vert. Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Last Interval Strokes/Length
The average number of strokes per pool length during the last completed interval.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap Normalized Pwr.
The average Normalized Power for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Power
The average power output for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Stroke Distance
Swimming. The average distance traveled per stroke during the last completed lap.
Last Lap Stroke Rate
Swimming. The average number of strokes per minute (spm) during the last completed lap.
Last Lap Strokes
Swimming. The total number of strokes for the last completed lap.
Last Lap SWOLF
The swolf score for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Last Length Pace
The average pace for your last completed pool length.
Last Length Stroke Rate
The average number strokes per minute (spm) during the last completed pool length.
Last Length Strokes
The total number of strokes for the last completed pool length.
Last Length Stroke Type
The stroke type used during the last completed pool length.
Last Length SWOLF
The swolf score for the last completed pool length.
Left PPP
The current power phase peak angle for the left leg. Power phase peak is the angle range over which you produce the peak portion of the driving force.
Lengths
The number of pool lengths completed during the current activity.
Max. Lap Power
The top power output for the current lap.
Max. Power
The top power output for the current activity.
Maximum Speed
The top speed for the current activity.
Multisport Time
The total time for all sports in a multisport activity, including transitions.
Muscle Oxygen Saturation %
The estimated muscle oxygen saturation percentage for the current activity.
Normalized Power
The Normalized Power™ for the current activity.
Pace
The current pace.
PCO
The platform center offset. Platform center offset is the location on the pedal platform where you apply force.
Pedal Smoothness
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
Power
The current power output in watts.
Power To Weight
The current power measured in watts per kilogram.
Power Zone
The current range of power output (1 to 7) based on your FTP or custom settings.
R. Pwr. Phase
The current power phase angle for the right leg. Power phase is the pedal stroke region where you produce positive power.
Rear
The rear bike gear from a Di2 sensor.
Repeat On
The timer for the last interval plus the current rest (pool swimming).
Rest Timer
The timer for the current rest (pool swimming).
Right PPP
The current power phase peak angle for the right leg. Power phase peak is the angle range over which you produce the peak portion of the driving force.
Speed
The current rate of travel.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Stroke Rate
Swimming. The number of strokes per minute (spm).
Strokes
The total number of strokes for the current activity.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time in Zone
The time elapsed in each heart rate or power zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The stopwatch time for the current activity.
Time Seated
The time spent seated while pedaling for the current activity.
Time Seated Lap
The time spent seated while pedaling for the current lap.
Time Standing
The time spend standing while pedaling for the current activity.
Time Standing Lap
The time spend standing while pedaling for the current lap.
Torque Effectiveness
The measurement of how efficiently a rider is pedaling.
Total Hemoglobin
The estimated total hemoglobin concentration in the muscle.
Training Effect
The current impact (1.0 to 5.0) on your aerobic fitness.
Training Stress Score
The Training Stress Score™ for the current activity.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Work
The accumulated work performed (power output) in kilojoules.
Copyright © Garmin. All rights reserved.GUID-45C11350-FBF5-4264-8316-A857189282E1 v4
