Changing the GPS Setting
By default, the device uses GPS to locate satellites. For more information about GPS, go to www.garmin.com/aboutGPS.
  1. From the watch face, select START.
  2. Select an activity.
  3. Select Options > GPS.
  4. Select an option:
    • Select GPS Only to enable the GPS satellite system.
    • Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility.
    • Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility.
    NOTE: Using GPS and another satellite together can reduce battery life more quickly than using GPS only (GPS and Other Satellite Systems).
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
