Using the Stress Level Widget
The stress level widget displays your current stress level and a graph of your stress level for the last several hours. It can also guide you through a breathing activity to help you relax.
  1. While you are sitting or inactive, select UP or DOWN to view the stress level widget.
  2. Select START.
    • If your stress level is in the low or medium range, a graph appears showing your stress level for the last four hours.
      TIP: To start a relaxation activity from the graph, select DOWN > START, and enter a duration in minutes.
    • If your stress level is in the high range, a message appears asking you to begin a relaxation activity.
  3. Select an option:
    • View your stress level graph.
      NOTE: Blue bars indicate periods of rest. Yellow bars indicate periods of stress. Gray bars indicate times when you were too active to determine your stress level.
    • Select Yes to start the relaxation activity, and enter a duration in minutes.
    • Select No to bypass the relaxation activity and view the stress level graph.
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
