How can I manually pair ANT‍+ sensors?
You can use the device settings to manually pair ANT‍+® sensors. The first time you connect a sensor to your device using ANT‍+ wireless technology, you must pair the device and sensor. After they are paired, the device connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. Stay 10 m (33 ft.) away from other ANT‍+ sensors while pairing.
  2. If you are pairing a heart rate monitor, put on the heart rate monitor.
    The heart rate monitor does not send or receive data until you put it on.
  3. Hold UP.
  4. Select Menu symbol > Sensors & Accessories > Add New.
  5. Select an option:
    • Select Search All.
    • Select your sensor type.
    After the sensor is paired with your device, a message appears. Sensor data appears in the data page loop or a custom data field.
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
