Using Run and Walk Alerts
NOTE: You must set up the run/walk interval alerts before starting a run. After you start the run timer, you cannot change the settings.
  1. From the watch face, select START.
  2. Select a running activity.
    NOTE: Walk break alerts are available only for running activities.
  3. Select Options.
  4. Select the activity settings.
  5. Select Alerts > Add New > Run/Walk.
  6. Set the run time for each alert.
  7. Set the walk time for each alert.
  8. Go for a run.
Each time you complete an interval, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds). After you turn on the run/walk alerts, it is used each time you go for a run until you turn it off or enable a different run mode.
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
