Setting an Alarm
You can set multiple alarms. You can set each alarm to sound once or to repeat regularly.
  1. From the watch face, hold UP.
  2. Select Alarm Clock > Add Alarm.
  3. Select Time, and enter the alarm time.
  4. Select Repeat, and select when the alarm should repeat (optional).
  5. Select Sounds, and select a type of notification (optional).
  6. Select Backlight > On to turn on the backlight with the alarm.
  7. Select Label, and select a description for the alarm (optional).
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
