System Settings
Hold UP, and select .
- Language
Sets the language displayed on the device.
- Time
Adjusts the time settings (Time Settings).
- Backlight
Adjusts the backlight settings (Changing the Backlight Settings).
- Sounds
Sets the device sounds, such as key tones, alerts, and vibrations (Setting the Device Sounds).
- Do Not Disturb
Turns on or off do not disturb mode. You can use the Sleep Time option to turn on do not disturb mode automatically during your normal sleep hours. You can set your normal sleep hours on your Garmin Connect™ account (Using Do Not Disturb Mode).
- Units
Sets the units of measure used on the device (Changing the Units of Measure).
- Format
Sets the device to display Pace/Speed Preference for running, cycling, or other activities. This preference affects several training options, history, and alerts (Displaying Pace or Speed) You can also change the Start of Week setting.
- Software Update
Allows you to install software updates downloaded using Garmin Express™ or the Garmin Connect app (Updating the Software Using the Garmin Connect App).
- Reset
Allows you to reset user data and settings (Resetting All Default Settings).
- Time Settings
- Time Zones
- Changing the Backlight Settings
- Setting the Device Sounds
- Displaying Pace or Speed
- Changing the Units of Measure
