Playing Audio Prompts During Your Activity
Before you can set up audio prompts, you must have a smartphone with the Garmin Connect™ app paired to your Forerunner® device.
You can set the Garmin Connect app to play motivational status announcements and training alerts on your smartphone during a run or other activity. During an audio prompt, the Garmin Connect app mutes the primary audio of the smartphone to play the announcement. You can customize the volume levels on the Garmin Connect app.
  1. From the Garmin Connect app, select Menu symbol or Menu symbol.
  2. Select Garmin Devices.
  3. Select your device.
  4. Select Activity Options > Audio Prompts.
  5. Select an option.
Copyright © Garmin. All rights reserved.GUID-B13F60F2-C67C-46A2-B03F-8F8FD01EF80A v7
