Data Fields
Some data fields require ANT+® accessories to display data.
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
The maximum temperature recorded in the last 24 hours.
The minimum temperature recorded in the last 24 hours.
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Cycling. The average cadence for the current activity.
Running. The average cadence for the current activity.
The average heart rate for the current activity.
The average percentage of maximum heart rate for the current activity.
The average lap time for the current activity.
The average pace for the current activity.
The average speed for the current activity.
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Running. The steps per minute (right and left).
The amount of total calories burned.
The distance traveled for the current track or activity.
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
The altitude of your current location above or below sea level.
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
The percentage of maximum heart rate.
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Cycling. The average cadence for the current lap.
Running. The average cadence for the current lap.
The distance traveled for the current lap.
The average heart rate for the current lap.
The average percentage of maximum heart rate for the current lap.
The average pace for the current lap.
The number of laps completed for the current activity.
The average speed for the current lap.
The stopwatch time for the current lap.
Cycling. The average cadence for the last completed lap.
Running. The average cadence for the last completed lap.
The distance traveled for the last completed lap.
The average pace for the last completed lap.
The average speed for the last completed lap.
The stopwatch time for the last completed lap.
The top speed for the current activity.
The current pace.
The current rate of travel.
The time of sunrise based on your GPS position.
The time of sunset based on your GPS position.
The temperature of the air. Your body temperature affects the temperature sensor.
The time elapsed in each heart rate or power zone.
The time of day based on your current location and time settings (format, time zone, daylight saving time).
The stopwatch time for the current activity.
The current impact (1.0 to 5.0) on your aerobic fitness.
