Navigating to the Starting Point of Your Last Saved Activity
You can navigate back to the starting point of your last saved activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
  1. Select Start > Navigate > Back to Start > Route.
    Turn-by-turn directions help you navigate to the starting point of your last saved activity if you have a supported map or are using direct routing. A line appears on the map from your current location to the starting point of the last saved activity if you are not using direct routing.
    NOTE: You can start the timer to prevent the device from timing out to watch mode.
  2. Select DOWN to view the compass (optional).
    The arrow points toward your starting point.
Copyright © Garmin. All rights reserved.GUID-46975363-04DD-408E-95A7-17D40075FC50 v4
